Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4998 Questions View all
iPhone 6 shuts down every 2-3 minutes.
Hi, I have a phone that shuts down every 2-3 minutes. I already changed the battery twice, both original. When charging it jumped from 1% - 37% to 78%. I have tested other batteries and had it factory reset, so it cant be a bad battery.
Anyone with a good solution?
Thx
Add a comment
1 Answer
Have you tried restoring it? If you do, choose “set up as new” because it may be a software issue. Hopefully that fixes it!
3 Comments:
Tried restoring both in DFU and Recovery mode. Still the same. :(
by
Only other times i have seen this in my store, is when the logic board is going bad and causing major errors, and later confirmed by apple.
by
Was there a specific chip that caused the board to go bad?
by
Add a comment
Add your answer
Thawng will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,058
