The Asus Zen AiO Pro Z240IC is an all-in-one desktop computer known for its 4K, ultra high definition screen and one terabyte Hard Drive. With plenty of processing power and memory, the device received the PCMag Editors’ Choice award in 2015.
23 Questions View all
Replacement for cracked screen
I had a problem when opening the aio and I cracked the glass of the screen.
does anyone know if you can find the replacement for the external glass part? the screen that has the touch?
I cracked it when opening and everything works, but it has the cracked lines and I would like to replace this screen.
please point me to where I can buy it.
thank you!
Add a comment
1 Answer
A lot of times they will have different models of the glass itself with touchscreens. It would be better to remove the screen if you are comfortable with doing so and look on the glass (probably will have a ribbon cable attached to the glass somewhere) and read the model numbers there and do a search off that.
Add a comment
Add your answer
gasguirre will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 425
