The Microsoft Surface Pro 2 is a Tablet/Laptop fusion that was released in 2013. The Surface Pro 2 is the successor of Microsoft's Surface Pro and uses Windows 8.1 through Windows 10.
How do I reformat surface pro 2?
I have surface pro 2, 128GB, windows 10 updated...can I reformat and still retain its windows 10? How? Thank you...
Add a comment
Most Helpful Answer
Yes, you can. Not a literal format though unless you want to re-install windows.
To reset the machine to factory defaults:
  1. Open settings by touching the windows start menu button, and click the gear icon.
  2. Open the "Update & Security" Menu and and go down to "Recovery".
  3. Under "Reset this PC" tap "Get started"
  4. Select the options you want and reset.
Hope this helps!
Score 1
Add a comment
You can also do a full format and fresh installation, make a Windows 10 boot drive and boot from it, it should allow you to fully format the drive.
Add a comment
Add your answer
Rene Manalili will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 7
All Time: 423
