The 2004-2008 F-150 truck was introduced in January 2003 for the 2004 model year as the redesigned eleventh generation of the F-150 lineup.
engine knocks when hot when going slowly
engine knocks bad when hot only when trying to go slow like a drive through. put in neutral and give a small rev and it stops.
Add a comment
1 Answer
First things first, get it scanned and see what codes come up.
Knocking implies bearings, usually big ends and it doesn't usually go away with a rev.
But what you call knocking I may call pinging. So are you saying it sounds like an old diesel with that death rattle they have in the top end. Or are you saying it has a dull thudding noise coming from the bottom end?
Add a comment
Add your answer
Robert Carter-Wood will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 80
