A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
214 Questions View all
Leaking water on the bottom
I Took the back cover off I ran the washer empty and there was no water leak .then ran with a load and there was water leaking . I seen the water dripping frim the bottom in spots but couldn’t tell where it was leaking from. Where would the leak be coming from and how do I fix ( you tube i’m Sure ) please and thank you
Score 2
2 Comments
Maytag washer ,bravos xl leaks from bottom what could be wrong.
by
My maytag leaking from bottom when it on spin
by
Add a comment
Most Helpful Answer
Cause 1
Drain Pump
The drain pump pumps water out the drain hose. If the drain pump is cracked or damaged, or if the bearings are worn out, the drain pump may leak water. The drain pump is not repairable—if the pump is leaking water, replace it.
Cause 2
Tub Seal and Bearing Kit
The tub seal might be torn, causing water to leak from the seal. If the tub seal is leaking water, water may leak through the tub seal and into the tub bearings. This can cause the bearings to fail. For this reason, if the tub seal is leaking water, replace both the tub seal and the tub bearings. Be aware that this is a complicated repair and will require disassembling most of the washer.
Cause 3
Tub Seal
Score 5
Add a comment
Our Maytag washer was leaking intermittently. Checked all the above mention spots for leaks and found none. Found there is a siphon break on the pump discharge where it goes through the back panel that was not always sealing properly when under pressure. Cleaned it of lint with a tooth pick and blew water through it until it would seal when sucked on. It now seals properly
Score 2
1 Comment:
Can u please specify where the siphon break is on the discharge pump? Do u have a photo of that?
by
Add a comment
Add your answer
Ryan Buil will be eternally grateful.
Past 24 Hours: 9
Past 7 Days: 27
Past 30 Days: 90
All Time: 37,279
