Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
165 Questions View all
Xbox button not powering on controller
I just got a new Xbox one controller v2, but it won't turn on when I press the Xbox button.
When I connect the USB cable it starts and works just fine, I can even remove the cable once the controller is up and running and it maintains its connection to my Xbox. But as soon as I turn it of I need the USB cable to "jump start" the controller again.
The Xbox button and everything works as intended after I turned on the controller (with the cable), it just doesn't work as an "on switch" for the controller.
It is updated to the latest firmware and I've tried different batteries.
1 Comment:
I have this problem but my controller won't turn on at all
by
Add a comment
1 Answer
Try a new controller. If it happens with that controller only, replace it.
1 Comment:
Thanks. The problem is just with this controller. But since the button works after I turned it on it seems like a software problem that could possibly be fixed (by a smarter person than me) without needig to replace it. Perhaps
by
Add a comment
Add your answer
Marcus will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,574
