The Skullcandy Hesh 2 is a set of Bluetooth wireless over-ear headphones sold by Skullcandy. The Skullcandy Hesh 2 model can be identified by model number S6HBGY-3xx.
7 Questions View all
No sound in one speaker
The sound in one of my headphone's speakers is rather faint and sometimes completely absent. I think it might be a internal wiring issue or a faulty speaker. Is there any way I might be able to repair or replace the speaker myself?
Score 3
Add a comment
1 Answer
Most Helpful Answer
@rhatten5 you need to check the wiring to the speaker that is not working properly. Depending on which side, it may be the crossover cable or the wiring right on the speaker. Yes you can replace it but you need to find a replacement which is not always easy. At this point I would check the wiring first. Post some images of what your speakers etc. Look like so we can see what you see. Adding images to an existing question
Check this video to get to your speakers etc.
Use a multimeter and check to see if there is continuity from the plug/board to your speaker. If not then it is the crossover cable. If there is then the issue is with/on the speaker.
Score 1
4 Comments:
when i connect my hesh 2 headset on aux cable i get sound on both ears, but when i connect on bluetooth i get sound only on the left ear.. what is the issue.. plz help fixit
by
I have the same issue.
by
I also have this same issue with my Skullcandy hesh2
by
I too :/ help please
by
Add a comment
Add your answer
Ryan Hatten will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 24
All Time: 3,710
