Why is my trigger stuck in forward or reverse
Trigger is stuck on unless the battery is removed or the directional selector is between gears. How do i fix it or where can i buy the parts.
Planemech -
I occasionally have that issue with one of my drills. I spray WD40 into and around the trigger and work it back and forth vigorously. Let the excess drain out. Usually that works. Electrical contacts are well above trigger housing area, so no problem there.
Good luck,
Russ
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 79
All Time: 3,368
1 Comment
It is a dewalt dw929
by planemech_2
