The BlackBerry Classic (also known as the BlackBerry Q20) was released in 2014. Model numbers: SQC100-2, SQC100-3, SQC100-5.
24 Questions View all
life expectancy of each battery
My cellphone just switched off on its own and wont respond even when i try to put a charger on,it looks as if the is no battery at all .Im now wondering if this has anything to do with the battery at all because i've had this Blackberry Classic since 2014 and i've never changed or touched its battery,is it dead just like that without warning orcan i change the battery?
Add a comment
1 Answer
Chosen Solution
Battery's are typical only good for a couple years then they really start to show there age. If the phone is doing nothing while plugged in it could be a board issue though. If the battery is easy to change that would be the first and easiest thing to do. If that doesn't work its time for a new phone.
Score 2
Add a comment
Add your answer
swmcitakali will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 21
All Time: 277
