The most popular option to light large areas of buildings. They come in a variety of connection types and power ratings.
22 Questions View all
What fluorescent starter to use with 9 inch fluorescent tube
I’m trying to get an old beer sign light to work. It has a small 9 inch tube. There was no starter, so I bought and tried a FS-5. It immediately blew the bulb. I think I must have the wrong type of starter
1 Comment
So it turns out that some form of a ballast or something else is in the power cord. Again this is a very old beer sign so it likely is not the way they do it now
by
Add a comment
Most Helpful Answer
Hi @jsanger
Some interesting Read
https://unvlt.com/pdf/literature/trouble...
Would be great if you can share more pictures.
Else another suggestion, to modify the current lighting to use LED modules.
If you use LED, you can remove away the ballast, if you had tested the ballast has failed, so as the starter.
Just for your reference.
https://www.amazon.com/Fulight-Rotatable...
Score 2
Add a comment
This beer sign light does not have a ballast, just a starter. How do I share a picture
1 Comment:
@jsanger use this guide Adding images to an existing question you need to edit your question and add the images to the question.
by
Add a comment
Add your answer
Jeff Sanger will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 113
