The Samsung Gear S3 is the third-generation Samsung Gear smartwatch, first released in November of 2016. Features a round OLED display running the Tizen OS. Model number: SM-R770NZSAXAR.
68 Questions View all
My Gear S3 charger Red led blinks after a while and the watch is dead?
My Samsung Gear S3 Frontier watch is dead, when put on charger red light normally lit, after about 1.5 minute it start flashing, i tried to remove it and re-put it many many time but no success
any advise or description of what it might be the cause.
Thanks for help..
Score 5
6 Comments:
Dear All
I’ve sent the watch from Egypt To Germany where it was purchased sent to a service center they fix it in the same day, few months later it was completely discharged and shut down the problem happened again, i was very upset, sent an Email to the service center in Germany telling them it is not fair to resend it again from egypt to germany asking them for advice, they responded that they can do nothing to me and it should be sent.
after googleing i found someone’s video who was talking about Gear S2 had the same problem he advised to put the watch on the charger for about 2 hours then pressing both buttons simultaneously for 10 seconds or more, i tried this several times until it worked with time and date reseted and the problem gone.
by
my watch have the same problem but after blinking the red light it gets overheated, im afraid putting on charging for an hour or two may it cost another problem
by
I currently have the same problem, but the fix you indicated with putting it on the charger and holding the two buttons for some time does not work. It seems to reset the watch, but when I take it back off the charging dock, it is dead again.....what do I do?
by
My watch has The dá-me problmeme. Its start above 1 month, return tô Work, and today camoback. Dont charge and blick a Red light.
by
please check my post for solving the problem
by
Show 1 more comment
Add a comment
1 Answer
Jeff
i found the solution for this case but it is hard, it worked for me perfect as i'm an electronics engineer
the solution is to open the back cover of the watch and solder 4 wires usb cable inside and connect it to any USB charger
it will open in seconds
again if you are not qualified for this, look for someone can do it for you
since then i never let my watch die again
look at this video this picture
Add a comment
Add your answer
Amr Agamy will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 89
All Time: 18,659
