Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
MacOS will not start
I have a new SSD installed and working in this computer. But MacOS wont’t show the installation screen because its grayed out.
I have tried to zap the PRAM, replace the backup battery, tried to boot from USB and Internet recovery, removed the RAM... everything.
Anyone got a clue?
Add a comment
1 Answer
Most Helpful Answer
The drive needs to be formatted with the correct format. Using your external drive to boot up with run Disk Utility and format the drive with GUID and a Journaled volume. Then you can install the OS.
Score 2
6 Comments:
I am a little bit more pro than that (thanks for the answer though). The problem is that the computer do not continue to disk utility.
by
OK, then lets get more details here as clearly something is a mis. Who's SSD (make & model) are you using and which port are you connecting to HD, optical drive or the spare and lastly, what is your MacOS.
Also can you post a screen shot of the Disk Utility screen Adding images to an existing question
by
@danj Is an Apple system update going to try to mess with the GUID format on this SSD?
by
@mayer - Yes! High Sierra will automagically update the drives partition from GUID/Journaled to GUID/APFS! This can be an issue if the person is trying to install an older OS onto the drive after its been setup with High Sierra.
If you are talking about service updates (not upgrading) they won't change anything.
by
There is a new TR200 drive from Toshiba, the original Apple SSD have the same problem, gray screen when booting.
by
Show 1 more comment
Add a comment
Add your answer
peter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 140
