Sony Xperia Z4 (known as Sony Xperia Z3+ in Europe). Smartphone with 5.20-inch 1080x1920 display powered by 1.5GHz processor alongside 3GB RAM and 20.7-megapixel rear camera. It was released in 2014.
20 Questions View all
Not charging after replacing battery
Hi, i just received a new battery for my Xperia Z3+ Dual (LIS1579ERPC).
I replaced it and it's not charging anymore. Conector seems to work because it makes the sound when connected and PC recognizes it but battery icon does not change to charging status and under batter menu it says "not charging".
Tried with USB and original charger. Both with the same result.
New battery is on 20% charge. I didn't do what the note inside the package says to drain it to 10% and charge it to 100% uninterrupted because of the problem explained above.
I tried putting back the old battery and it's charging OK. I don't have another phone to try the new battery.
What can i do?
Add a comment
1 Answer
Most Helpful Answer
It's a faulty battery. Try contacting the supplier / seller you got it from for a replacement.
Score 2
1 Comment:
Thanks, i bought it from iFixit and used a forwarder so sending it back for a replacement is not an option.
by
Add a comment
Add your answer
Andres Maidana will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 237
