Repair guides and support for the ultra-light laptop computer line by Toshiba.
35 Questions View all
Toshiba Portege Z30-B Keyboard Replacement
Hello,
I want to replace the keyboard on my Toshiba Portege Z30-B, but there is currently no repair guide, parts or tools for the keyboard of this specific model. I am assuming that it may well follow the same format (and possibly even use the same parts) as another Toshiba model that is covered by ifixit, but not sure which one that would be. Could someone advise me as to which guide, parts and/or tools I might be able to use from ifixit that would work for the keyboard from this model of laptop?
Best wishes,
Henry
Add a comment
Chosen Solution
@hentug should be the same as on the Z30. Check this video for more information
Score 2
Add a comment
Most Helpful Answer
The vast majority of laptops are pretty much the same. Sometimes there's a screw or two in the bottom, hopefully with a picture of a keyboard next to it, that you have to remove. Then it's usually just a matter of releasing the tabs either along the top or along the bottom of the keyboard in order to angle it up so as to release the ribbon cable(s). Sometimes, you have to remove a bezel between the keyboard and the hinge to reveal a couple of screws securing the top of the keyboard. This bezel may just unclip, or may be retained by screws on the bottom.
If you look at a few iFixit guides and YouTube videos for the nearest matches to your model that you can find you should be able to work it out. You'll find the iFixit Jimmy (see the Tools Store) or a thin blunt knife is invaluable both for releasing the keyboard tabs and for removing a bezel, of that's required.
Having got the keyboard out, check that the replacement has the same configuration of ribbon, and of course, is the right nationality. Hopefully you'll find one on eBay quite easily.
Score 2
Add a comment
Add your answer
Henry Tugendhat will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 2,245
