Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
Ice maker not working
Ice maker quit making ice. I have changed the water filter and not getting any water still. Does it take a while to begin working after changing the filter?
Score 2
Add a comment
1 Answer
Check your solenoid or float and ball assembly, however yours is equipped. If solenoid equipped, is it getting voltage? Is it a type that may be cleaned and checked by you? If float and ball, check and clean.
Add a comment
Add your answer
Karen will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 16
All Time: 440
