Guides and repair information for coffee and espresso makers from Jura Elektroapparate AG, a Swiss developer and distributor of home appliances.
102 Questions View all
Re-assembled Jura Impressa F50 - Loud Noise at end of cycle
I replaced the drainage valve in my Jura F50 machine and it now makes coffee :)
Unfortunately it also make a very loud noise as if something is stuck at the end of the coffee making cycle. Its almost certainly something I have done wrong in re-assemble but everything seems to work (Coffee good, coffee grind where it should be and no obvious leaks etc.) Any ideas on what this might be?
Score 2
1 Comment
The problem actually seems to be worst when a clean is done after switching the machine off. The loud noise goes on for some time and the machine resets rather than turning off (Next attempt to power it off immediately powers it down)
by
Add a comment
Most Helpful Answer
Feeling kinda foolish now. All I had to do was let it complete one cycle without the coffee grind bin in place (Tray in but collection bin out). Must have been out of position but now its ok.
Score 1
Add a comment
Exact same problem, also with an F50, and your easy fix worked a treat!
5 years later almost to the day, thank God for internet!
Robert Dunkley, you’re a gem🙏🏻
Add a comment
Add your answer
Robert Dunkley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 1,317
