Kia introduced the second generation (JB) in the early 2005 model year in Europe and for model year 2006 in North America, based on a redesigned platform shared with the Hyundai Accent.
14 Questions View all
How to check if my 2007 Kia Rio base model cooling fan works?
How do I check if my 2007 Kia Rio base model cooling fan works? We are replacing the radiator because of a "bug puncture", but the fan doesn't seem to be running either. Is it suppose to run all the time or just when the car heats up?
Score 1
Add a comment
1 Answer
Chosen Solution
Electric engine-cooling fan motors only run when the thermostat opens or coolant temperature reaches a set temperature.
So no, it doesn't run all the time.
edit: to check the operation of the cooling fan, with the radiator fixed, let the car run for 5-10 minutes, this should be sufficient for the engine to heat up and meet the criteria for the fan to start. Just keep an eye on the intrument-cluster for coolant temperature so that it doesn't overheat.
Score 2
Add a comment
Add your answer
reneesown2 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 1,058
