1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
Trackpad and Keyboard ghosting
Since some days my MacBook Air 13 Inch Late 2010 has a problem.
Both the Trackpad and the Keyboard do some entries without typing or clicking anything.
Its like somebody types on my keyboard or uses my trackpad without any physical input.
I wonder if the problem is not the keyboard or trackpad itself because both of them started to act weird at the same time.
Is there maybe a cable that could be responsible for this?
Would be glad if someone ever had the same problem and hopefully a solution.
Add a comment
1 Answer
Chosen Solution
Yours system uses a single cable to send the keyboard & trackpad signals to the logic board. What can happen is the battery swells pressing on it. I would first recommend checking your batteries health using CoconutBattery paste a screenshot of the apps window here for us to review Adding images to an existing question depending on what this shows you’ll likely need a new battery. MacBook Air 13" Late 2010 Battery Replacement
Another source of problems is the trackpad its self as its the junction point for the cables. a liquid spill can mess up the trackpad or if the liquid gets to the back side mess up both. At this point you’ll need a new trackpad and you may want to replace the cable as well. MacBook Air 13" Late 2010 Trackpad Replacement
MacBook Air 13" Late 2010 Battery Image
Guide
Difficulty:
Moderate
15 minutes
MacBook Air 13" Late 2010 Trackpad Image
Guide
Difficulty:
Moderate
iFixit Image
Guide
Difficulty:
Very easy
2 - 5 minutes
Score 1
4 Comments:
Hello Dan
Please check the screenshot attached :)
by
It looks OK, you'll need to replace the trackpad & its cable
by
OK and you are sure that its not only the cable but also the trackpad? How is it possible that also the keyboard acts so weird? :(
by
OK, Lets think it like this: A cable to B cable to C where A is the keyboard and B is the trackpad and C is the logic board.
So A & B can encounter problems if the cable between B to C is bad. Its also possible A and B can encounter problems if B its self is bad. Does that help in visualizing the issue?
We are replacing the two elements that can effect both the keyboard & trackpad.
by
Add a comment
Add your answer
jimmy industries will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 1,750
