Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
105 Questions View all
How can I improve the battery charge rate while using navionics?
iPad battery loses charge while operating navionics navigation program, even though it is constantly plugged in to charge on a 12 volt system. Need to improve rate of battery charge somehow.
Add a comment
1 Answer
Most Helpful Answer
Connect your iPad to a Mac system and run on the Mac CoconutBattery it will tell you the health of your iPad’s battery. Lets see what you find out.
You also maybe hitting a limit here with this iPad series running this type of program.
Have looked at getting a newer model? The older APU’s pulled more power and given your use the APU is stripping the power faster than the battery (or charger) can offer it. You could try using an external battery pack but I’m not sure that will offer enough juice if your direct power feed is unable to offer enough current either.
Score 1
Add a comment
Add your answer
Liz Crawford will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 63
