Haswell business laptop introduced by Dell in 2013. This system is notable for being the first Haswell business laptop released, but has multiple known problems - including AMD GPU failure. A new battery will operate the laptop for ~4-7 hours, depending which one is installed.
replacement keyboard not working
Hi there,
I have recently replaced my keyboard with a non-original keyboard and it works only a few minutes and stops. After every BIOS update it works again and stops after a few minutes.
Any idea how i can get this non-original keyboard to work?
Regards,
Siviwe
1 Comment
You tried to use your keyboard in safe mode if it is working then there must be an app causing error
by
Add a comment
1 Answer
Chosen Solution
Need to try a DriverPack Solution Software and update the keyboard driver. If the problem persist your new keyboard might have a defect.
Add a comment
Add your answer
Siviwe Xegwana will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 6
All Time: 319
