The Canon PowerShot A720 IS is a point-and-shoot camera with 8.0 megapixel resolution and a 6x optical zoom.
11 Questions View all
Will not hold time and date
When I switch the camera on, the set time and date message comes on the screen. This has to be set before the message clears from the screen. The next time the camera on you have to go through the same procedure again.
Add a comment
Chosen Solution
I have a similar camera (A570 IS) and mine has a second type of battery right beside the two main AA ones. It’s under a cover marked “CR1220” which refers to the type of that second battery. Pull that cover up, replace the CR1220 (or whatever battery type your camera has) and that should fix the problem.
Score 4
2 Comments:
i tried that and it didn;t work
by
@williams679 what make and model camera? what were the issues and what did you try?
by
Add a comment
Most Helpful Answer
If the battery level drops to low, a board will lose its memory. Replace the battery.
Score 4
1 Comment:
I have already replaced the batteries but problem still exists.
by
Add a comment
Add your answer
rogerdeans will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 968
