Released December 2012, identified by model SPH-L300.This Android phone holds 4G LTE data, a memory card slot, 5-megapixel main camera, front camera and Samsung's S-Beam for fast file transfers.
7 Questions View all
Samsung Galaxy S5 G900F
Galaxy is not in the menu this refers too: Samsung Galaxy S5 G900F
When the phone is switched on, the start up logo sits there the phone does not boot up?
I cannot gain access to the phone, no matter what I connect the phone too, (i.e. Kies, Smart switch?
Add a comment
Chosen Solution
This is usually caused by either one of the following:
* System software getting corrupted, can be caused by a system update, not enough space on phone or for no apparent reason.
  • Power management chip going faulty (This requires micro-soldering board level repair to fix)
  • eMMC chip (Flash memory / a.k.a hard drive) going faulty (This requires either getting the flash memory chip replaced or reprogrammed by a JTAG (flashing box, again like board-level repair).
If you are lucky sometimes this can be fixed by reflashing the System Software (Firmware) on the phone.
Here is a link on how to reflash firmware on Samsung devices:
http://updato.com/how-to/how-to-install-...
Score 2
Add a comment
Thanks for your reply Ben.
I tried using Odin but it failed “error” no pit file. I next used smartbox got pit file tried to flash phone still no luck. It must as you said be an electronic fault. I need info from the phone but I can't access it.
I'll have to take it to a reputable phone service to be repaired if it can be!
Thanks once again for insight!
Add a comment
Add your answer
John Banks will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 394
