Guides for the Wi-Fi version of the iPad Mini 3 (A1599). Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
61 Questions View all
Home Button Failure after Display Assembly Replacement
After a successful replacement of the glass on an iPad mini 3, the undamaged home button is not functioning when pressed. There are no errors reported on start-up. Given these circumstances, does this mean the connector on the logic board has been damaged? Again there are no signs of damage that I can detect.
Add a comment
1 Answer
Most Helpful Answer
Assuming you don’t have a teeny microtear in the flex then the MOST LIKELY problem is a parts problem on the screen. These are notoriously bad. Definitely make sure to test home button function before sealing it up.
Score 1
Add a comment
Add your answer
Michael Scott will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 55
