Device and repair guides for the 2016 Samsung Galaxy J5 Prime smartphone, model number SM-G570Y or G570.
81 Questions View all
How can I turn on my phone?
i was using instagram and my phone turned off suddenly. now it is not turning on even with volume up and home button and power button method. it do not on red flash light when i charge it.help me please
Score 2
Add a comment
Most Helpful Answer
Try putting it in Download Mode, Vol Down + Home + Power Button. The screen should go Blue-Green background or, rarely Black with text.
Read the screen and see which key is to restart (typically vol down) and see if that works.
Otherwise you phone may have an internal issue and need to see the current flow and find the culprit.
IF your phone has gotten wet, then there is a chance that the water inside created an issue.
good luck
Score 2
2 Comments:
i have done that and nothing seems to work
by
Thank you so much.
This was a great help for me... no words!!
It had been hours working on phone.finally happened to read this.
God bless
by
Add a comment
Hello,
As i see your phone is not turn on
some time this happen due to over use you phone your battery reached in almost dead state.
At that time you have to give a shock your phone battery via another recharge battery and when your phone battery have some charge to turn on your indicates then plug in into charger Then your phone automatically comes into charging position.
If this doesn’t work try to contact the service center, it might have some internal issues of hardware.
Hope this will help you
Thanks
Add a comment
Add your answer
Sana Jamshed will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 1,070
