This is an ASUS laptop with a 15.6 inch monitor released in 2014, identified by part number R510LA-RS71.
4 Questions View all
ASUS R510L screen not switching on after motherboard replacement
Hi,
I have ASUS R510L that I' have change motherboard. Everything is working except the screen. When I connect to external monitor, I get output correctly. So my issue is with the screen. Also the computer fails to reset surely for I already upgrade from windows 8.1 to windows 10. I tried static energy discharge (holding power button for 30, 60, 120 seconds etc.) still can’t get the screen run up.
Any Guru advice to fix up will be appreciated.
Thanks
Add a comment
1 Answer
Chosen Solution
Check the connection from lcd to mobo is secure, it needs to be making good connection to get output to the display.
1 Comment:
Tkx @Minus. I've tried a lot of time but still not working. However, I ordered another cable connector hoping that is the issue, for the screen itself doesn't seem to have any flaw.
tkx again.
by
Add a comment
Add your answer
Jaures will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 136
