Repair guides and support for Kenmore washing machines.
The hot water selector is not filling
hot water selector is not letting hot water flow. Just dribbles. cold water selector is fine
kenmore model 110
Add a comment
1 Answer
Most Helpful Answer
@deltabatt
this sounds like a bad hot water inlet valve. You need to give us a complete model number for more information on the part and the repair. Also, there should be a screen between the water hose connected to the inlet valve and the valve itself. Remove the hose and check that the screen is not clogged. you can remove it for test purposes.
Score 3
1 Comment:
Thanks a lot! Have good day.
by
Add a comment
Add your answer
Ernie Vetkoetter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 39
