This complete home theater system includes a slim design silver DVD receiver with a progressive scan five-disc DVD changer with multi angle and zoom functions, a 720-watt amplifier and Dolby Digital/DTS/Dolby Pro Logic II built-in. It also includes five matching silver full range satellite speakers and a 120 watt subwoofer.
17 Questions View all
won't stay powered on
this system has been in storage for 12 years. i powered it up today. the red stand by light comes on, indicating system not on. when i press any of the disc or am/fm buttons, the display lights up indicating system on, but the goes back to system off mode in a few seconds. something i’m missing?
Score 1
3 Comments
@sarah_rver is your system a JVC TH-M303?
by
yes it is. had it for 13 years
by
@sarah_rver just to clarify, it turns on but after a few minutes it turns off. Any LED lights on or any sign of life when it turns off?
by
Add a comment
1 Answer
Most Helpful Answer
Neither the user nor service manuals provide any particular clues based upon what you have described. Therefore, I must start with the typical failure. Disconnect the speakers and try again. I expect that the unit will power up normally.
You can reference the service manual here: http://www.go-gddq.com/upload/2010-02/10...
The main power amp resides inside the subwoofer. Check to see if there is a protect light on the subwoofer.
If there is a light or the unit only “works” with the subwoofer disconnected, I would suspect that one of the amp chips inside the subwoofer is defective and further investigation is required. There are 2 large black amp-packs inside the subwoofer (STK413-400 and STK413-=430). One or both of these may be defective.
Try removing the speaker connections and report the results here.
Dan
Score 2
Add a comment
Add your answer
Sarah Hughes will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 22
All Time: 1,000
