A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
Washer is blinking and error message
What does it mean when time remaining says 5d and the cycles are blinking
Add a comment
1 Answer
Most Helpful Answer
You probably used the wrong soap in the machine which resulted in excessive suds. Try a different soap which does not produce so much suds. You can read this guide for more information.
Score 1
Add a comment
Add your answer
Nora orso will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 396
