Nikon's D3200 DSLR has 24.2 megapixels. This model is geared towards casual photography enthusiasts with advanced specifications and performance.
66 Questions View all
Please, why this error message, this memory card cannot be used.
Memory card error message: This memory card cannot be used. Card may damaged. Insert another card.
That is the error message displayed any time I inserted a memory card into my Nikon d3200 camera. I have tried new memory cards but the error message persist.
Score 1
1 Comment:
Please can you clarify: are you saying that other memory cards work, or that you get this message even with other memory cards?
Memory cards all look the same but they're not. Not all memory cards are compatible with all devices.
by
Add a comment
I don’t know to much about this problem but the camera is not compatible with all memory cards
here is a list of compatible memory cards you should check if the one you are using is on there
https://www.mymemory.co.uk/nikon-d3200-s...
hope this helps
Add a comment
Hola,mi camara tiene el mismo problema ,la tarjeta de siempre ha dejado de leerla,todas dan error incluso las que aceptan,que puede ser el problema,gracias.
Add a comment
Does it read on a computer?
If not your card (if it has one) lock switch is on.
If not, replace the batteries , or put the SD card into a computer.
Add a comment
Add your answer
Eugene Odogwwu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 621
