Radiator is leaking not much but constantly
Radiator is leaking, still can manage with filling up
Hi Horst. If you’re certain your coolant leak is coming from your radiator, the only proper fix would be to replace it. There are some shops that repair radiators, but I would replace it. If you want to do the repair yourself here is a video of the removal process. Remember to keep your old radiator cap, as most new radiators don’t come with a new cap. When you’re finished be sure to refill and bleed the cooling system. I hope this helps. Good luck!
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 18
All Time: 238
