The CASIO CDP-230R was released in 2013 and is preloaded with over 150 songs. Main unit is black or silver and may come with a stand.
2 Questions View all
6,3mm jack stick, stuck inside socket
Situation is such: I accidentaly kicked the plugged in jack stick and it broke off the tip of the stick deep inside the socket. I am unable to get it out and since the keyboard thinks there is a headset plugged in, the speakers are silent.
Solutions already tried and tested:
  • Glue on the end of a stick
  • Glue inside q-tip
  • Yelling at it
I took apart the keyboards front panel, but the jack stick socket is still unaccessible (see photos).
Any ideas? Current solutions include: Drilling a small hole in the back of the socket or sending it to a professional (not the iFixit spirit).
Add a comment
1 Answer
Chosen Solution
Hi @nikolajskov ,
Can’t you unscrew the circuit board and move the board far enough so that you can access the underside of the headphone jack and then unsolder it from the board? There appears to be only 7 screws holding the board down.
Getting a replacement headphone socket may be the problem, although with it removed you may have better access to it and perhaps you can free the piece lodged inside..
Just a thought.
Score 2
Add a comment
Add your answer
Nikolaj Skov Wacher will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 382
