In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
SSD upgrade 2018 model
Hello,
Is it possible to upgrade the SSD in the latest MacBook Air (2018) model, or has Apple soldered it making this impossible?
Thanks…
Score 1
3 Comments
There is no 2018 model as of yet. The most current model is the Early 2017 13"
by
Thanks Dan!
From what I understand from the demo below, a 2017 13"'s SSD should be replaceable; do you agree?
Thanks...
by
Yes you can replace it with either the OWC SSD or the custom Apple SSD designed for your system.
by
Add a comment
1 Answer
Most Helpful Answer
The 2017 model uses the exact same design as the 2015 model. The only difference was an upgraded CPU chip as Intel stopped producing the chip Apple was using.
Here’s the IFIXIT guide you’ll need to follow: MacBook Air 13" Early 2015 SSD Replacement and here’s the needed SSD [linked product missing or disabled: IF123-123]
Score 2
Add a comment
Add your answer
Dav will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 3,841
