Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
97 Questions View all
Home button only works long press
My home button only works when long press to reset iPad so holding down the power button and home button together to do a hard reset but once on the home screen the home button will not work? Any ideas
many thanks
2 Comments
Any history about this iPad ? Description points lo a logic board issue..
by
Hi
yes the screen was changed and the finger id works but not the home button but also if you try another working home button it still does not work
by
Add a comment
1 Answer
Chosen Solution
If you changed the screen yourself, then you’ll need to open it up and closely inspect the Home Button flex. Look for any tears along the flex or a kink due to an incorrect bending of the flex. The other possibility is that the connector on the logic was damaged.
Score 2
2 Comments:
Can’t be the flex as tried another working flex and home button still does not work and I was careful slotting the flex back in to connection
by
It is likely a logic board issue, although button is one the two functions rely on different circuits and once you rule out bad connector or a bad flex there's nothing else left I could think of. I had a similar issue not long ago with a customer's iPad Air, but it had signs of previous repair attempt with melted plastics.
by
Add a comment
Add your answer
Arran will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 163
