Repair guides for Samsung Galaxy J3 smartphone.
Phone won't charge normally
My phone won't charge unless I wrap the charger cable tightly around my phone. I can't put my charger in normally.
Add a comment
Most Helpful Answer
@matt100121
check your charging cord and see if the connector is bent or has some loose contacts etc. try a different charging cable. If the cable is good then the issue is with the charging port of your phone. You may need to change it by soldering a new connector to the board. Use this guide Samsung Galaxy J3 Middle Frame Bezel Replacement to get to the board. Let us know what you find.
Score 3
Add a comment
Have you tried different chargers? If not, try another charger as it may be a problem with the charger.
1 Comment:
If I cant get the charger inside is I,am going to need a new phone is it broke for good
by
Add a comment
Add your answer
Matt will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 355
