Battery operated Thomas the Tank Engine ride-on train with track.
Not working at all
I have just been given this by my sister. I have had the train on charge for few hours but nothing no led, music, movement, just nothing all the components and connections look OK. How can I find the issue to fix the train. Thanks
3 Comments
Hey, Kelly. Do you have a multimeter?
by
Hi yes I do own one
by
It is working for music but not moving
by
Add a comment
1 Answer
Chosen Solution
Here's a teardown of the train. With the charger unplugged, set your multimeter to DC Volts and measure the voltage of the battery at the battery terminals. It should say on the side of the battery what the voltage is supposed to be. If the battery measures the correct amount, measure the voltage again with the black lead on the negative battery terminal and the red lead on the far end of the red wire. I would think it terminates at the back of the switch. If there is no voltage there then the in-line fuse is blown and will need to be replaced.
Thomas Ride on Train - System Diagram and Components
Score 1
Add a comment
Add your answer
Kelly Kennedy will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 32
All Time: 2,197
