The Samsung Galaxy Tablet E 9.6 was announced June, 2015 and released on July 2015. When repairing this device, a few basic tools available from ifixit.com will be necessary. Samsung Galaxy Tab E 9.6 is available as 8GB or 16 GB versions, expandable by micro SD. It was sold in two colors: Pearl White and Metallic Black.
55 Questions View all
Battery Drops When Charging
I have my tablet connected to its original charger. Also i have an app that needs to run 24/7 (app does background work, internet and disk i/o) and also prevents the screen to go off because it needs to be active all the time. The problem is that the battery drops even when iam charging it. Without the app, the device charges correctly. Is there a way to fix that?
Add a comment
1 Answer
Most Helpful Answer
Hi!
You need a more powerful power adapter that the one that came with the tablet. You should look for one that can output more than 5V/ 2A (or that are certified as “fast charger”), like these ones: https://amzn.to/2zSTLHx
Score 1
4 Comments:
This is what i use.
by
Is the cable also fast-charge-capable? Have you tried and even more powerful charger? Or lowering the display brightness a little?
by
I dont have another charger but i lowered the device's brightness. Nothing worked.
by
What about putting it in power-saving mode?
by
Add a comment
Add your answer
George Paouris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 130
