Home Bread Maker released in the late 80's. This Bread machine has a standard size vertical bread pan and multiple settings to making a variety of doughs and breads. Identified by model number HB-B102.
Mixing Paddle won't turn
Mixing Paddle does not turn whether in machine or out. Motor and pedestal for paddle work without pan but will not work in pan.
Score 1
Add a comment
1 Answer
Most Helpful Answer
I had a similar problem, you need to perform the steps to replace the shaft seal then clean and lubricate the shaft. It may take a lot of force to remove the shaft. I used a dead blow rubber hammer and a drift to drive mine out. You need to be careful not to damage the shaft or bearing in the bread pan while driving the shaft out. As far as lube I used 3 in one oil but I’ll probably re-lube with silicone plumbers grease.
Score 1
Add a comment
Add your answer
Janet Hendricks will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 1,344
