Repair information and guides for the fifth generation of iPhone. Model: A1387
Problems After Screen Replacement
See video for details. It basically starts up with a bright white light and then turns into vertical lines. It also sometimes displays 5 lock screens vertically. I have already tried a soft reset, but it had no effect.
Score 1
Add a comment
Chosen Solution
Do you still have the original screen in a somewhat working condition? If so, try the original screen and see if this problem persists. That way we can rule out the screen.
Update (10/07/2018)
@blewisgabriel Sounds like we have our problem solved! If you wish you can buy another replacement screen at the link below. Go ahead and mark this as correct for completion sake.
iPhone 4S Screen
Replace a screen compatible with iPhone 4S. Includes all of the small parts pre-installed in the assembly, saving time and increasing the quality of your repair. 3.5 inch IPS LCD (640 x 960 pixel) Display. Image
Product
iPhone 4S Screen
$34.99
5 Comments:
I am working on that now...I will post an update.
by
@blewisgabriel Sounds like a plan! Keep us posted :-}
by
@ajcooke01 Well, I put the old screen back on and it works without a problem. I guess it is just a defective screen.
by
@ajcooke01 I tried putting the new screen back on and now the picture vibrates. Do you know anything about this?
by
@blewisgabriel You mean the phone won’t stop vibrating?
by
Add a comment
If you still have the original LCD screen, put it back in and see if it does the same thing. It might be a defective / bad 3rd party screen you have there, or it has been damaged. A similar sort of white to gray vignette and vertical lines problem happened to my LG Optimus L90 - that is, after I put it through some physical stress tests.
Add a comment
Add your answer
Benjamin Gabriel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 9
All Time: 121
