Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
Is my display broken?
Dropped my iphone X in the shower, screen cracked starting from the topleft corner. Took of the display and saw no water inside. My battery was empty and it showed the apple cable logo when I tried powering it on. But after charging it for a while my screen is now black and it flashes random “lines”. Is my display broken or something else? It’s weird it can show the lightning cable fine but when charging it shows a black screen. Don’t want to buy a display and then find out it’s not a display problem.
Add a comment
1 Answer
Chosen Solution
You like to live dangerously, don’t you ;>). The iPhone X is water resistant, not water proof so there’s always a risk of water damage.
Realistically speaking, you have a damaged screen. Unfortunately, the only way to properly troubleshoot your problem is to try a known-good replacement screen. If the replacement screen doesn’t solve your problem, then you wold have a logic board issue.
Score 4
3 Comments:
Livin' on the edge xD, figured it is broken anyways, might as well DIY...
by
...it's better to burn out than to fade away...
-Neil Young
by
@refectio you say potato I say patato
by
Add a comment
Add your answer
KWH will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 132
