Released in March 2017, the G6 is LG's flagship phone running Android 7.0. This device is available across all major wireless carriers. Physical repair of this device may eliminate water resistance and cause the device to be vulnerable to water damage.
55 Questions View all
SIM card not recognised
I have an LG G6 with the same problem... How exactly do you "open up the phone" I can't really do that with mine
Score 3
1 Comment
I moved your comment from an old question about an iPhone to here so you get the answer...
by
Add a comment
1 Answer
Chosen Solution
This is the guide you will need to follow to open your phone and access the sim card slot.
Sometimes the pins are dirty or bent. The fault may also be with the SIM card itself. Try a new SIM card first before you open the phone. Good luck.
LG G6 Motherboard Replacement
Score 4
1 Comment:
403 Forbidden access
by
Add a comment
Add your answer
SammyK will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 5,632
