Repair information for the Samsung Chromebook Plus. Released in February of 2017. Model number: XE513C24.
23 Questions View all
Replace keyboard on Samsung Chromebook PRO/Plus
I recently spilled liquid on my Chromebook Pro and some of the keys are no longer working. I tried to remove the keys to see if any residue was causing them to not work but to no avail. Is there a DIY to replacing the entire keyboard?
Score 1
Add a comment
Most Helpful Answer
This is going to take replacing the entire palmrest, keyboard, track pad assembly for the most painless repair. The assembly usually runs between $50-80 and the repair should take about 30min if you're comfortable with laptop and phone repairs.
Score 1
Add a comment
You’re better off sending it off to Samsung to deal with this one. Also, isn’t this chromebook quite new? You should check to see if it is still under warranty.
Add a comment
Unfortunately it's gen 1 purchased right after it's release date and out of warranty. Thanks for the suggestion though.
Add a comment
Add your answer
Joe Dellava will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 1,063
