The Nerf N-Strike Elite Mega Magnus is Nerf blaster released by Hasbro in 2014.
3 Questions View all
How do I repair the chamber flap on the Nerf Mega Magnus?
I recently bought a used Magnus and I took notice why people didn’t want it. The chamber flap, which probably isn’t it’s name, is too loose or weak to hold a mega dart being chambered into the barrel. It just gets pushed out of the way, making me have to push the dart back in to have it fire effectively. Is there any way to just fix it outside the gun or do i have to screw inside and replace a spring?
Score 1
Add a comment
If you take the rifle apart, there is a place for a bunch of the safegaurds so you dont chop of your finger, the red safegaurd is what is blocking it, tap it, and the trigger should pull back
Add a comment
I had this problem too. You want to take the gun apart,remove the barrel and then take out the front orange piece.it separates into two parts and on the Inside is a screw and Spring,this controls the little plastic piece that slides up to stop the flap. you may need to tighten or loosen the screw,or just move the piece up and down a bit to loosen it up.
Add a comment
Add your answer
Cowerosity will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 13
All Time: 532
