The Canon Powershot A590 IS is an 8 megapixel digital point-and-shoot camera with a 4x optical zoom and a 2.5 inch LCD screen.
Lens error, restart the camera
I am getting this message when I press the on button. The lens is not retracting in.
Lens error, Restart the camera.
Can you please help?
Add a comment
Chosen Solution
Pinky Kasotia , this is usually caused by sand or grit interfering with the lens extension mechanism, or the camera's been dropped with the lens extended. It is also possible that the camera has been powered on, but the lens had been blocked preventing its extension....okay there are plenty of causes. Check on here for a more concise solution. Good luck
Score 2
Add a comment
lens do not get back when on/off button is pressed.
Score 2
1 Comment:
same answer as above :-)
by
Add a comment
make sure you are not holding the lens when you turn the camera on.
Score 1
Add a comment
can you help for restart the camera
Score 1
1 Comment:
Camera lens does not move when switch.
by
Add a comment
Add your answer
Pinky Kasotia will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 25
All Time: 6,311
