The De'Longhi EC155 is a Pump Espresso and Cappuccino maker.
25 Questions View all
Why is it making weird sounds after it ran out of water? And no crema?
It ran out of water while making some coffee, and now it makes a very small amount of coffee and with no crema. Is it true that if I ran it with no water it means the machine is broken for life?
Add a comment
1 Answer
Chosen Solution
It is likely there’s some air inside the circuit where there should be just water..running the machine while dry might have caused some overheating but I would be a bit surprised that broke it for good. Try running a few coffee making cycles without actually using coffee. If you still have the user manual you may also check what to do before first use and do that again.
Score 1
Add a comment
Add your answer
Gabriel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 265
