Repair guides and support for the Motorola Moto G6 Play, Released May 2018. Model number XT1922.
25 Questions View all
Moto G6 Play replacement screen 1mm too short
I know this is going to sound weird but I ordered a screen from 2 different suppliers for a Moto G6 Play and both replacement screens are 1mm too short. Everything lines up at the top and the shape is perfect but there is a gap at the bottom. The flex cables work and are a perfect match to the original. Anybody else have this issue?
Score 6
3 Comments
Yes got the same problem, I recommend buying with frame assembly
by
Our shops have ran into this issue as well. We now buy it with the frame only.
by
Unable to find XT1922-9 replacement lcd w/ frame...
by
Add a comment
Chosen Solution
Hey Jestin, I have since discovered there are 7 variations of the G6 Play. Some of them use a 150mm screen and some use a 152mm screen.
If the supplier doesn't specify, you will most likely get a 150mm.
I found an eBay seller that lets you pick which one you want and it worked great.
Score 3
1 Comment:
I had the same issue today with the screen i received from a local supplier today. Everything works on it, its just short.
I end up replacing the screen anyway.
by
Add a comment
iFixit sells genuine Motrola parts. I would sugget you search on iFixit for availability of the specific moto part you need in order to ensure a proper fit. The genuine parts are going to be a lot more reliable!
Add a comment
Add your answer
brentongraber will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 21
All Time: 2,209
