HP Photosmart printer introduced in 2010. This printer is considered ePrint capable. Has a card reader that supports Memory Stick Pro Duo, Memory Stick Pro-HG Duo, MultiMediaCard (MMC), MMC Plus, Secure MultiMedia Card, Secure Digital (SD), SDHC. An adapter is required for MMC Mobile, Secure Digital Mini, and MicroSD cards. This printer uses a 4 color semi permanent printhead.
8 Questions View all
Replacement part needed for paper output tray
The moveable stop guide which slides out from within the output try has broken. I would like to replace it. How do I do this? What is the part or part number? Where can I get this from? Thanks
Score 1
Add a comment
1 Answer
Chosen Solution
Don’t try to find a tray unless you get a great deal on the part and print photos. What I’ve done on these for mine and my dad's when they inevitably broke (we didn't use them for photos) is take the trays apart, throw the 4x6 inserts out, and "fix" it for free. This DOES remove the dedicated tray (and 4x6 support because HP tied it to that tray >_<), but it works if you can forego the option and do not use 4x6 or 5x7 photo paper.
Yes, I know this is a "photo printer," but its photo printing capabilities are a joke. It's fine for handout photos, but you wouldn't want to use standard CMYK for photos taken with a proper Mirrorless or DSLR camera. It lacks a PK (grey) cart, which any decent photo printer has. Good ones worth using in the studio have PK, LC/LM/LY, or orange inks.
The problem is a plastic piece in the tray that likes to snap, and you cannot get the part from HP without paying too much for plastic or swapping the complete printer. Yes, the delete is dirty, but it costs about as much as a whole printer in many cases, whereas the needed T10 Torx driver is MUCH CHEAPER. Putting a drop of Super Glue on the part to keep it in place works, too, but it is subpar as it is still there, and the printer may still try to grab it. Taking it out completely nips the issue.
Score 1
Add a comment
Add your answer
Andrew Gordon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 529
