Repair and information guide for the Kenmore Refrigerator 253.6375*30*, a top freezer model with automatic defrosting and an anti-sweat heater switch, made by Electrolux Home Products - Minnesota. This page covers information for model numbers matching the pattern 253.6375*30*.
1 Questions View all
Evaporator Coil transition freezing
I have a Kenmore fridge. Model 253.63712300. The piece at the end of the evaporator coil keeps freezing. This is the transition where the line gets much smaller in size. This is the only part of
the coil that is freezing and is causing my fridge to not cool. Thank you for any help.
Add a comment
1 Answer
Chosen Solution
Hi,
If there is ice forming on a pipe feeding the evaporator, you have a problem with the sealed system.
Depending on your location, you’ll most likely need a licensed refrigerator repairer to check it out. This is to ensure that it is done safely and correctly in accordance with the environmental laws that might apply in your area.
Also they have the appropriate equipment to tap into the sealed system to check for restricted flow of the refrigerant, correct pressure, any leaks etc.
Score 2
Add a comment
Add your answer
Paul Hageman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 73
