Released January 2016, Identified by model number BDP-S3700
Why does the open/close button not work
I have disconnected both the audio and HDMI cable from my device.
After turning on the device, pressing the open/close button has not effect. The green power led is on.
I have tried resetting by holding on the open/close button, and the plugging in the power cord. This did not fix the problem.
Any suggestions or advice would be gratefully received.
Add a comment
1 Answer
Most Helpful Answer
@igreid wonder if it is in demo mode. While the player is turned on, press  ■ (stop) , RETURN, (pause), and then the SUBTITLE  button on the remote to disable it.
You can also try to open the case by inserting a paperclip in the hole of the drive
Score 2
1 Comment:
Thanks for the suggestion. This did not help.
This is the second unit I have had this issue with
Not sure what to do next.
by
Add a comment
Add your answer
Ian Reid will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 318
