Released in May 2014, the Chromebook 2 features an 11.6" display, Intel Celeron processor, and a 16GB SSD. Identified by model number XE500C12-K01US.
14 Questions View all
How do I fix broken audio jack?
One day, I go to use my headphones on my Samsung Chromebook 2, but I am greeted with very distorted audio. I tried everything I could to try to fix it. (Wiggle the headphone jack, remove anything in the audio jack port, etc.) After a while I found out the the headphones work perfectly fine when the mic button is pressed on them. I tested another pair of headphones, and the same thing happened. It seems that whenever I use a pair of headphones with three plastic rings on the jack, the sound is very distorted. BUT, when I use headphones with only 2 plastic rings, it works perfectly fine. Any ideas?
(My headphones worked perfectly fine before, so something must have happened to my Chromebook port.)
Add a comment
1 Answer
Chosen Solution
Fixed by bending a piece inside the jack.
Add a comment
Add your answer
Tyler Meece will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 344
