The DualShock 4 CUH-ZCT2 was announced in 2016 to replace the CUH-ZCT1 controller released in 2013. This controller is similar to the previous model.
274 Questions View all
Is JDS-040 correct replacement for CHU-ZCT2U (or/and FJDS-040)
Controller model: CUH-ZCT2E.
1) Would FJDS -040 work if my current/existing board is JDS -040?
I can mostly found FJDS-040 which seems to be different compared to my JDS-040.
My USB charging port:
FJDS I keep finding on ebay etc.
As you can see board layout is little bit different. Would those FJDS one work?
2) On USB boards I see square with number 1 or 2 (on different board), since both are JDS-040 boards, what those means? In short, can I replace JDS-040 board ignoring those numbers.
Example:
Score 1
Add a comment
Chosen Solution
The FJDS-040 is also known as JDS-040 or JDS040 and should be compatible for as long main board controller is a JDM-040 which it will since your original is a JDS-040.
Score 3
1 Comment:
@oldturkey03 Awesome, glad to hear it! Thanks for the reply and also explaining main board relation, really helps me in future, something to add into personal knowledge bank.
by
Add a comment
Looks like it is! According to this guide on iFixit though.
DualShock 4 CHU-ZCT2U Charging Port Replacement
Score 2
9 Comments:
Thanks! Any idea are FJDS-040 still suitable ? Have not yet found any reliable source for JDS-040 boards, only see FJDS-040 being available.
by
@ajcooke01 Thanks for the link! Unfortunately they dont display bottom of the board. I noticed at ebay and amazon which includes these "JDS-040 With 12 Pin" but upon zooming they all read "FJDS-040" instead just "JDS-040". Since boards layouts are slightly different, quite confused if FJDS and JDS is considered as "compatible" with each other.
by
@coffeeod Well, I guess we are in a bit of a pickle here...
Could you link me to the board(s) you are looking at buying?
by
@ajcooke01 example when searching for jds-040 on eBay I get these https://www.ebay.com/itm/12-Pin-USB-Char..., when you look at images you noticed it's actually an fjds-040. Comparing that to my posted image (my usb charging port) board layout is indeed different
by
Show 4 more comments
Add a comment
Add your answer
Michael Schales will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 58
All Time: 7,732
